Having Issues with motor recognition on vesc
Hello for anyone who wants to help that would be amazing if not, I understand. I have downloaded bldc tool for windows and if will not run any firmware at all or pick up any default settings. I am going to try and download ubuntu or linux, but wanted to see if I can run windows before i start my download tomorrow for the new operating system.
Were you able to connect?
no I refreshed my pin and it still would not connect 4.12
I tried uploading the 4.12 default firmware, would not load and have it connected to everything needed obviously. I feel like there were things in my command prompt that I needed to change, I have only used the link given to downlaod the bldc itself for windows.
“Refreshed your pin”? Does the VESC currently have f/w on it? Are you plugged in via mini USB? Do the lights turn on?
I have a usb cable from the vesc to the computer, nothing comes up when refreshed or plugged in ever since I’ve downloaded it :confused:
Did you make sure the USB cable has data pins? Some cables only supply power.
4 pin usb-a connector to computer and 5 pin usb-b connector to vesc
