I can make a quick kinematics test. Give me a little bit of time
This deck looks amazing and Im curious to how it feels when riding. I see that there are slots milled out for the truck baseplates and would a belt drive still be able to fit on the deck or does there need to be a riser between the deck and the truck? And do you want to go for a kicktail?
Because of the mold geometry we canāt add a kicktail. Creating a custom mold would be to expensive at this point.
It depends on what motor diameter, mount lenght and wheel diameter you choose ;D. But no worries a belt driven setup will fit for sure.
quick test: this is with the raw cncād deck, the finished one has a little bit more of clerance. Trucks: TB 218 Wheels: 6 Inch, similar to SixShooter Pneumatic wheels Riser: 1" (25mm) (just a constraint dimension)
edit: I changed the distance between the bearings on the wheel dummy. gives a litte bit more of turn
Count me in for the pre order Thinking a sneaky 4wd set up for the rainy season.
Iām in for it too
Iām in Madrid and would totally be down for one. I will have a set of Hummies new hubs hubs that oughta be perfect.
we need more spanish builders on the forum
I can keep track of about 4-5, but im sure there are more.
Looks fantastic.
Following
Que pasa cabrĆ³n? No reconoces tu raza? Anytime. I am around
Just take our money
How much moneys? This thing is awesome!
So 6ā would work fine or do you need more wedging to get better clearance?
Interested in this! Any estimate price? Iām guessing this is a stiff deck that wonāt flex?
Well my @dareno friend, seems that he doesnāt live in San FermĆn, Spain, rather in BerlĆn, Germany, soā¦
On the other hand, correct me if Iām wrong ā¦but it seems we just got here the first dedicated-specifically designed-custom build-production run-Esk8 deck ever created in the short history of this hobby!
So having it onto the longer wheel base would also provide more clearance?
Larger enclosure (battery)?
Iād argue that the Ollin Freeride or Enertion Raptor carbon fiber deck were first but this is a cool offering. Definitely interested in seeing more.
