Are you asking if it will work as a replacment part on the VESC? If so @JohnnyMeduse is the man to ask.
Luckily you came to the right place. You have a bunch of smart mother f@ckers that know all types of this stuff. @Blasto & @JohnnyMeduse are the two guys I know that know just about all vesc things. There are more here too that might chime in too.
Thxπ β¦
it look good, which part number did you use?
Wow dam i dont see that vd 232?
But still dont work
Can you send me picture?
Yes i can.
Can you check to see if the 3,3V is not shorted to the Ground anymore?
Ok give me 2 min
285ohm . . .
Ok so it should be alright, can you post your parameter?
Parameter? The 285 ohms?
In diod mode reads 285
