Hi guys,
I’am Pjotr 17 years young. I live in Belgium.
I want to make a longboard that can climb an 10% hill. What i have: Board + Trucks Motor Mount (50mm motor) Charger 6s 4A 97mm wheels Battery%Bms 6s 5A charging (i go bypass the Discharge)
I was thinking of change my setup to a 10s or 12s setup for more torque. 10s setup: I was thinking of use this motor 6355. Is see that the motor have 8 mounting holes. Will it fit on my mount? I know when i go for a 10s setup i must change the charger and bms. I will maybe use a vesc.
the battery will be 5000mah, on what setup can i ride the longest?
