I have an aftermarket motor controller i purchased. So the board i have is and 800w e-mad off road. I purchased from an individual and the original motor controller was fried. So now how can I go about wiring the original wireless remote receiver circuit board to work with the new controller?
The wiring are same if the board is of the same spec , to the controller and the motor you can , but in your case you seem to have gone for bldc motor controller , whereas a skateboard uses vesc or esc , As the motors for skateboard comes under the spec 170 kw and so whereas the motor controller used is for e bike conversion bldc
