I’ve connected VCC, GND, TX and RX from the UARP port to the Bluetooth HM-10.
This is the one I bought:
https://www.amazon.com/gp/product/B015R3IJ4I/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
I’ve installed VESC Connect for Android and I was able to connect to the module, it has a solid red led. The baud rate was left at the 9600 by default and app to use was set to PPM and UART, but I can’t datalog or read config from VESC, no information is received by the phone.
What else could I try?
Blasto
February 16, 2017, 4:58am
2
did you connect like this?
BLE VESC
VCC 3.3V
GND GND
RX TX
TX RX
Blasto
February 16, 2017, 5:02am
4
Eboosted:
should I switch it?
yep, don’t worry, nothing damaged
Wow thanks a lot Blasto! There should a step by step somewhere. I’ve been battling for hours. It’s connected now!
Blasto
February 16, 2017, 5:26am
6
did somewhat of a write up on the vedder forum and I think there’s some info buried in a nunchuck thread (fuck knows where that is)
http://vedder.se/forums/viewtopic.php?f=15&t=75
thamer
June 11, 2020, 3:09am
7
Guys, maybe you can help me. I am having the same issue connecting my HM-10 to my VESC 4.12.
I cannot find a proper schematic for connections instead of this one, and I am not sure if it is correct neither the direction of this.
I did the connections as @Blasto mentioned, however I could not connect it to my Android, it appears BLE error connection.
If we could revive this topic and someone could help me I will appreciate that.
