While setting up my vesc it suddenly startet to smoke and died.
Vesc: Maytech 2.18 Motor: Turnigy sk3-6364-245kv Kontroller: nunchuk Batteries: 2X Turnigy 5S 5000 mah 20-30C
Following a vesc setup tutorial, rebooting after every setting I changed, I managed to set my vesc up for bldc with a nunchuck kontroller and all worked fine!
Then I tried to to set my vesc up in FOC mode for a smother ride. Following the tutorial I First red default config, reboot and then started the “MEASURE R AND L” test. All worked fine. Applied the results. Rebooted. Started the next test and cal CC after that, applied and then reboot.
Then I tested to accelerate with cruisecontroll pressed in. The motor started to turn slowly but when I let go of the accelerator the motor started to turn fast back and fourth faster and faster and the vesc started smoking and i pulled out the battery as fast as i could but then damage was already done and the VESC is dead.
These were the settings I runned when it happend and some realtime data. Please help me to find the problem or wrong setting.
