I am looking to build a diy board from these and have NO IDEA what ESC or BATTERY TO GET… i am not sure what is compatible… its very hard to figure out and looking for a point in the right direction… or a simple answer of just what to buy… JUST IN TERMS OF COMPATIBILITY… range can be ANYTHING… but note the deck will be very long and can fit a larger battery… I have no idea if size of battery even corresponds with range or speed at this point…
battery MUST be able to plug directly into wall with AC adapter cable… no balance chargers allowed
TBH i have done much research but havent gotten a clear answer… like the two hub motors specs read 36v and 1000watts… what kind of battery is suitable for this???
even though its a dual hub system… does that just mean it draws twice the amps?
the P number isnt just a difference in how the batteries are linked together though? it literally implied a bigger battery… a similar sized batter with a higher P number would mean a smaller S number?
i ask because i have been hearing that anything below 1P is bad news for some reason? and 2 P is better… any thoughts on this?
10s means 10 cells now the “P” means how many in parallel so a 10s2p means 10cells and 2 pack so in total its 20 cells total. Now the reason u want to stack them in parallel is for one u get more range and 2 u pull more amps , also depending on the motor watts u go fast, u also want to have more amps so that u don’t voltage sag as much is u have a 10s1p depending on your cells let’s say 30q u can only pull 20amps and your going to have a lot of voltage sag typical motors single drives can pull 60amps (not really good at explaining the technicality sorry )
Not sure where you did this “much research” but sounds like you just went out and bought some motors and are now just assuming things will work out always plan a build. Especially if you’re unfamiliar with what you’re doing.
And sorry if i sound like a douche, thats not my intent
Ok… i didnt buy the motors exactly… but these motors are the only ones that will fit my trucks… ALSO PLEASE NO ALTERNATIVE MECHANICAL SUGGESTIONS… THAT COULD BE A SEPERATE BUILD… I MUST USE THIS MOUNTING STYLE FOR REASONS… didnt even want to make it a mechanical / truck mold thread…
You’re not the first person to ask these questions. All these answers can be found by SEARCHING and READING. Serisiously. Devote like an hour or two to solid reading of posts on here and you’ll have your answers
