When I set up the vesc I choose no regeneration brake
When I do the set up for the vesc I choose no regeneration brake
Well, you got a few issues here. First, change your braking current to ~ -25. each battery can handle 4a and 7 of them can handle max 28a. Second, donāt go downhill with your battery full unless youāre trying to commit a suicide.
thatās not an optionā¦
Ooo ok My brake cut off bc full battery dnow the hill
bingo. donāt charge your battery completely full or donāt go down that hill at the beginning of your ride
Ooook It costs me 150$ to understand this bent the front truck And what about my brake is to high bc I love the brake on my board Do a good job at -60
motor min or battery min?
Itās not what you like, itās what the batteries are capable of. You will kill your battery pack pretty fast.
Ok but the brake will still good at -25 iām Scary it will be not enough
Are you going dual or single motor? -25a should be fine.
is it your motor min or battery min?
this is kinda important
Two sk3 6374
Just post a picture of your vesc settings.
alright. so you can leave the -60a alone, but I recommend lowering the battery min to -15a or so
Is that the same settings you have on both vescs? If so lower the battery min to ~13a and leave the -60.
Ok I will do it can you explain to me what is the battery min
Ok thank so much
