I have a Flipsky 7550, and I’m having trouble identifying the white pin headers for communication with peripherals. What kind of connectors are the white pin headers? The pins are spaced 2mm apart. I’m not sure if they’re JST or something else.
Suspect they are jst-ph connectors which are exactly 2mm between pins. As opposed to jst-xh connectors which are 2.54mm. But dont quote me on that.
Lets wait for someone who knows for sure to confirm.
Edit: did some searching and it does appear to be jst-ph. Measure very carefully and if its 2.0mm spacing then thats the one.
