I burn my can transiver, but i solder new one and not working.
What does it mean that it does not work? does it not turn on? turns on but does not send status…? we need more info please
With so much information I’m sure we will have it fixed in 5 min
Which version of VESC and from which vendor?
Dont send estatus
4.12 . T.boards
OK so if you soldered it already the warranty is void.
first check that the VESC has the chip soldered correctly check the settings to make sure, on both VESCs check the other VESC if it has the chip working correctly report back
maybe some pictures if you are unsure about the soldering quality
