Need help and advice. My first build ever, I bought a kit from DIYelectricskateboard.com, now I’m starting to have regrets in doing so. I purchased their mechanical kit which I upgraded getting their 110 wheels and dual motors. The first issue:
The kit was incomplete missing the bracket for the dual motor setup. Messaged them about that issue “they said the bracket is discontinued and they will refund me $15”
I asked: is the bracket necessary for helping support the motor mounts.
DIY: no the new motor mounts are good enough that it doesn’t need the bracket.
My question is to you guys is that true or are the blowing smoke up my ass.
My second issue is that I upgraded the wheels to their 110 since I’m a heavy set guy thought maybe the big wheels would be good for me. But none of the hole matches up to the pulley system. Can anyone give some advice on that please
For the enclosure I am getting it 3D printed hoping it will be good. And I am carbon fiber skinning the board to strengthen it. Since I’m I’m a heavy guy
iff you have enough space on your axle you could maybe place some spacers between your wheels (bearings) and the hanger. this would move out the wheels slightly meaning you should be able to move the motor pulleys and mounts a little. this might be enough to create the space you need for your motors.
