Fairly new here, but definitely have been reading before I was even a member. I read another post about someone else’s board being slow but it seemed they got it figured out with gear ratios. I have a pennyboard that I put bigger trucks, 270kv motor, 70mm wheels, and had a 16:48 gear ratio on a 6S battery with the same ESC as the Meepo board. Was getting about 7-8mph full charge…
Recently upgraded to 90mm wheels, 15:36 gear ratio on a HTD 5m belt, and it is way more sturdy than what I had. I am STILL getting only 8-9mph full charge and I did gain more torque going uphill but where is the speed! I used a calculator at a low 60% efficiency and it says I should be getting 15.8 MPH…What am I doing wrong?
kind of in shambles at this point, I took everything off but these were some pictures without the ESC in, I can put it back together and take some more tomorrow. But that ESC lets you choose 6S 7S or 10S
When I charg on the imax b6, I stop them at 12.6V but I have not checked current on them yet. I used a voltmeter before when they weren’t on full charge but still had a little over 11V on each
Haha, good to know. Had a fellow on here a while back that had his pack all kinds of miswired. Do you notice any improvement when the batteries are fully charged, rather than nearly dead? (11v is getting near the bottom.)
I haven’t ridden too much since the 90mm upgrade but it seems full charge did nothing since I only gained a MPH on full charge and bigger wheels from the 70mm. The remote does have a fast and slow mode and i was on the fast mode when i tested
I think the meepo board uses hub motors so the esc is designed for hub motors with a max rpm limit. I have one of there ESC. My set up is 10s 7000mah, 40/20 gears and 90mm wheels and dual 200kv motors. I get like 19 to 22mph. And I use the same brand of batteries as you
