I have a 10s5p battery with a 6374 192kv motor. I took it out last night and it went plenty fast. Took it inside and looked at the vesc software and I am guessing it somehow reset everything. My motor settings are max: 70A, min: -60A, Battery max is 40A and min is -12A. The voltages are 34, and 31. Ive spent all day trying to figure this out and can’t.
Oh maybe thats why, I charged it for about half an hour just to test if it was the charger and it didn’t do anything. But this brings me to another conclusion, my LED always states that my battery is at 100%
Yeah you have the same issue I did. You got the wrong lcd display / you have it programmed wrong
Not sure which one you have, and if I did, I wouldn’t be much help anyways. What I did was swap the reader over to volts and then just got used to reading it as 42v is topped off, and 30 is lowest I would ever go
turn off the battery then hold down the black switch while you turn the battery back on. It should flash and allow you to scroll using the front buttons to set it to 10s.
Okay it looks like I pick a letter between L, F and P and then select a 2 digit number. I have a 10s5p battery. I was not sure what the letters meant but I put 10 in
Thanks a ton man! It showed 2%, then 100% and then 99% and now it still says 100% but i’ll keep on fiddling with it to try and figure it out. I really appreciate it though. I hope my battery was just out and that is why I was having a really weak motor originally
At 30v it should be reading the 2% mark which is why the board was not moving. Get it set and hopefully everything is hunky dory. Remember the 10s should read 42v on max charge.
Don’t let the battery get that low again either. If it gets too low you will struggle to charge it with a 2a charger and it can get damaged. Good luck!
