Hello,
I have come up with the parts to buy for my esk8, but I am paranoid that my electrical components will not work (or work bad) together. I don’t have too much money to spend, so I really can’t afford burning something. I would extremely appreciate if some experienced DIY esk8 builder could confirm that my electronics would work properly. I’m attaching a brief description of the components as well as the links. Any help is appreciated. Thanks in advance!!!
The antispark power switch is unnecessary if you just use a loopkey.
Be careful with Flipsky ESCs, they have a very high failure rate. Sometimes it’s better to just get a better one instead of buying twice. But in theory that ESC would work well for this.
My second-biggest gripe here is a single 6354 means your brakes will kind-of suck. Consider a 6384 solely for the braking ability.
Put the drive wheel on the rear heelside.
But the biggest problem I see: Don’t buy anything until you have the deck+enclosure and helmet sorted out. Don’t leave the enclosure until last as an afterthought, or you will likely be in very bad situation.
I don’t get why would I want to put the drive wheel on the rear heelside?
Also, do you think I need a helmet? I am not experienced, for sure, but I am not planning to go too fast.
Please, follow this. You do not want to regret not having one. I unfortunately had a 30 second concussion not wearing a helmet, using a defective remote (didn’t know at the time), and was going over 34mph. Lesson learned.
ABS enclosures suuuuuuck. They will crack around the boltholes every single time. Also, that enclosure is very unlikely to fit that deck. Foam seals are horrible. You want a flange and a form fit enclosure that seals with butyl tape.
