I’m working with @DarkVortex to make a robot with a 4s1p battery, would we still need a BMS for something that small or can we skip it and just use a charger?
If we need it what are thoughts on these items
If your using batteries you need a BMS. If you can charge to 95% and discharge to no more than 30% everytime you are ok for a few charge cycles, then you need to balance charge manually. A BMS makes life a lot easier.
When in doubt, bring in the robot experts haha!
I’m just offering advice based on experience. @DerelictRobot is an expert and professional in the. I don’t he will dane to visit you plebes
Haha I meant it as a joke because whenever I see KaramQ TSG you to call a thread he tags you 3 times in one line… (ps mmaner advice is always correct even if it doesn’t sound so)
This is entirely up to you as a design choice. Personally I find it easier to build in a BMS just so you don’t have to bother carrying around and hooking up a balance charger, but I’ve done both.
I recently built out a 4S8P pack for a friend who is building a hexapod- using a similar BMS to what you picked out there. Charging just requires a CC/CV charger intended for li-ion/lipo.
I only did that once buddy
Only time I ever saw you close a thread
