Hi, I need a little help setting up my vesc (this is the first time I’ve done anything like this) I have a stormcore 60 with 2 motors and this battery pack - http://www.diyeboard.com/10s5p-18650-lithium-battery-pack-36v-10ah-360wh-with-charger-p-655.html
I’m unsure of some of the settings in the vesc tool when setting up my Battery.
Battery Cells = 10 Battery Capacity = 10.000 Ah
Battery Current Max = 25 A Battery Current Max Regen = ?
Max ERPM = ?
Are the ones I filled in correct and any ideas what the ones with a question mark should be?
Also would this is the remote I have -
http://www.diyeboard.com/new-version-3-speed-mode-remote-controller-rc7-for-diyeboard-p-690.html
would this connect to the stormcore or do I need a new remote? if so any recommendations on a inexpensive one that would work?
