Hey there, I could use some help from yall…finally setting up my board and I am having an issue at the very last step. I had both motors running fine the entire time on the bench and even kept testing as I put the enclosure to the board. Finally got everything situated and one of the cables pulled right out of the CAN BUS connection when I was wiggling some shit around
No big deal, stuck it back it, hot glued it, tested it, and it worked fine. Then, I got everything screwed on tight and now only one motor will run! The master motor runs fine, but no signal seems to be getting to the other motor for some reason. Rechecked the CANBUS cable to the best of my ability. Took it back out, re-situated it and still nothing seems to work. I plugged master VESC into the slave motor and that still runs fine. Is the only ( most likely) possibility the can bus connection? No idea why it isn’t working still. Is there a better way to "rebuild " it like popping out the little metal connector completely and re wrapping the wire before I stick it back in? Is there any other work around, troubleshooting to do here? Really want to finally get this thing running right after months of waiting I am about to break something…
Any ideas? Thanks!
