Hi,
Since recently my board has been throwing DRV8302 error in the first minute of riding, after that it’s entirely fine.
Anyone knows why? I’ve got the most recent firmware and 4.12 hardware.
It just stops accelerating for a second when I’m getting the error but it does concern me.
Edit: Adding more info, updated firmware to 3.38 and problem was gone for a ride, but now it’s back again…
This is a metr.at graph, that shows the start of a run with multiple DRV8302 faults in a very short timeframe. The second one is after a restart, riding to where I had to go.
These are my settings:
Motor Settings GENERAL:
Motor Settings BLDC:
Starting to get quite desperate to solve this issue. It’s extremely annoying to place my board on the road when everyone’s watching and not being able to ride off in one go
Thanks in advance!
@onepunchboard Yes, ERPM is limit as that’s my way to limit my topspeed.
is the box beneath it checked? “Limit erpm with negative torque” ?
nope, my ERPM is also not reached.
[Bump] Added more info to the first post. I’m still having issues with this error and I can’t seem to find the culprit.
Your regen seems high. Have you checked the vesc for solder balls/damaged components?
Have you ridden it in the rain? How waterproof is your enclosure? Have you checked the caps?
Do you run sensored? You were braking for almost a minute in the second log. Were you going downhill or something?
I have set my battery regen fairly high indeed. Should be 10A instead of 30A.
Never the less, I don’t see why that would cause the faults at the start where I’m not even braking.
The VESC seems totally intact. My enclosure is pretty much water proof and the vesc is trapped in some type of foam material, making it nearly impossible to have gotten wet. I pretty much never ride in the rain.
I have not checked the capacitors. I’ll try to when I’ve got the time.
I run uncensored and yes, there is a very steep hill when I come back from the GYM, as I’m very cautious, I apply a constant brake and ride really slowly down . Cause I cannot brake with my foot.
