the pc does not recognize the device when I plug it in
Humm⌠could be a corrupted firmware of bootloader, if so you need to program it manually with an st-link.
how do I do that?
You probably didnât do anything, Iâve seen some issue like this with this firmware. What is your VESC (sorry I did not read the hole thread)
its a flipsky 4.12 vesc, 2 of them
Are the 2 doing the same thing?
yes they are and they were connected over can bus
After I did get them to connect vesc tool said it could not read firmware, is it possible the firmware was working and now isnât?
Can you see some ligh when you power them ?
there is a green and a blue light
Try to disconect the can⌠then plug usb each one into the computer (I donât if it is possible) and check if at least they are reconize
I already did connect the can bus and tried that, but it stills says cannot read firmware
Cannot read firmware version, it says
Hummm⌠Really look like a corrupt firmwareâŚ
can I reinstall firmware with this: https://core-electronics.com.au/st-link-stm8-stm32-v2-programmer-emulator.html?utm_source=google_shopping&gclid=Cj0KCQiAuf7fBRD7ARIsACqb8w7qMpX1RHZhqiZf73OYv6xvBC4OYVsA7RvdI22x77R9lu11Kk23HMUaAq2VEALw_wcB
Yes it should work
ok ill get it now , thanks for your help
No problem. It is always a pleasure.
Itâs a long-shot, but try this: Assuming you are using a Windows machine, disconnect the USB to your VESC, open the Device Manager and expand the Ports sub-menu. Note what current COM port is listed (if any). Now connect your VESC and observe if a new COM port is added in the Device Manager. If a new port is added, right-click on that port and select âUninstall deviceâ and also select âDelete the driver softwareâ. Go to the top menu of the Device Manager and click Action, âScan for hardware changesâ. Your VESCâs COM port should be re-detected and added to the Ports sub-menu. Right click on the newly added COM port (it may have a yellow exclamation next to it), then select Update Driver, âSearch automatically for updated driver softwareâ. Once the driver has been updated for your VESCâs COM port and status looks normal, go into the VESC tool, select the COM port that matches what you saw in Device Manager, then connect. Post the latest output that you get from VESC terminal.
Also try turning your pc off, connecting the usb and starting it up while connected. I had a 6.6 that would only read doing that.
