Hey all, my BMS arrived today and I almost have the wiring down but still got a few questions.
I’m gonna run two lipo packs 5s1p 8000mAh 30c in series.
Using this BMS.
In the diagram, he has the battery packs positive and negative terminals switched. That is, the right packs positive wire ends up being the negative while the negative wire from the right pack becomes the systems positive wire. Is this correct or should I flip them so that they match accordingly?
Yes just extra balance leads, you would be better off using the diagram I posted earlier, it has the balance lads in order.
I don’t see red going to black. I see the POS lead going to the charge port and to the ESC and NEG lead going to the BMS the to the charge port and ESC.
Ahhhh, i see that now, right by the battery before the 5.5mm connector. I dont know how I missed that. The connector color is what you should pay attention to,
Make sure you measure the balance header with a multimeter before plugging anything in. Very easy to blow out your BMS with the wrong balance order/voltages.
