Im going to be running 2x 5s lipos with a bypass daly 10s common port with charger/loop key. ive got 12awg wire with xt90 connecters, is there any other adapters I would need as the daly has blue and black cables already and not sure how this should look?
Thats a bit confusing. How and why would you want to bypass a common port BMS, which is designed to manage both charging and discharging?
Even if you installed the loop key inbetween the battery and BMS, your 10s balance lead would remain connected, right?
I think it would be better to install that loop key either on the positive lead or after the BMS on the negative lead.
Still just an amateur at this ESK8 stuff so I’m trying to figure it out too.
I jumped the gun on the bms. ive heard It can be done, just haven’t seen too many clear pictures or diagrams
Need a fuse on the charge port
needs a fuse on both
I would not put a fuse on the ESC.
The esc is a fuse. Albeit a rather expensive one.
