Hi guys! I have problem with sk3 245kv 6364 motor inner fan. I f***ed up those threads, because couldn’t open it even with heat applied. So I Drilled of heads of the screws.
I’ve tried to make new threads in different places of that fan, but there is only 2mm of material so screws were not holding in them: I could easy damage threads by just tigtened the screws, and there was not much pressure applied.
So I tried to glue nuts from other side of fans wall. I used glue that is strong, flexible and can stand up to 120°c. So nuts holding very tight and it will work, but my concern is that next time I’ll need to open my motor some of those nuts could get loose from twisting screws to open motor. So it could lead to problem to get open that motor.
Maybe i just dont get it actually
but as far as i remember the Vent is a structal part of the Motor
The Fan function is not needet… TRUE … but it supports the bell isnt it ?
