Don’t make a dual loopkey. If it’s a 40A battery, that’s well within the limits of an XT90 and 12AWG silicone-insulated finely-stranded tinned copper wire. (Sometimes called “superworm”)
If you can solder then run both 14AWG red wires into a 12AWG red wire and then through a loopkey. Then you can split back into two 14AWG wires if you want to.
Only work on one polarity at a time and tape the end of ALL wires you aren’t CURRENTLY soldering. Remember, you can’t turn off a battery while you are working on it.
The battery has two charge ports. Im not sure if this means its a double battery or just has two ways to charge. I only say to make one to avoid confusion. Originally, this was the idea i had in mind.
@b264 Yes yes I understood my battery was not compatible with 12s, and i wasnt risking it on anything rated 14s (was shooting for at least 15s for safety)
I was already looking at high voltage vesc’s but as i am currently on a very tight budget, i ordered the esc’s for generic “brand name” prebuilts like mine. They should at least allow me to use higher gears with less of an issue and have more wires for accessories.
Also i am currently about to start work on the loopkey for this thing. I can provide any photos for anyone curious or willing to help. Here’s what I’m working with….
These are the oroginal replacements i put in which were rated 25 amps 52v just like the originals, but these were smaller, had no connections for lights
Same manufacturer too if I’m not mistaken.
Old ones are inside and im chairlocked at the moment.
These are the ones I’m waiting for to arrive
(The photo specs aren’t for mine since i had to select from a dropdown menu but that’s essentially what they are)
Can you help me with a diagram bc this is not my expertise and i keep going in circles. Like I think i know what to do but it’s hard for me to draw out. Have a form of severe autism
