I’ll start off by telling you the main parts I am planning on using
Motor: Turnigy 5055-280KV Brushless motor
ESC: X-car Beast series ESC 120A
Batteries: 2x Turnigy 5000mah 3S 20C lipo pack
EDIT : Should I upgrade to a 236KV motor?
1- Will all these parts work together?
2- If the motor specs say “Voltage: 10S Lipoly” does that mean I need a 10s battery system?
3-In the X-Car beast series ESC’s is that switch to turn on/off the whole system or just the ESC?
4-How do the brakes work on the ESC
1 yes but you are still missing parts
2 No that only What most effocient
3 not 100% but Thats momentary on off you need a real circuit breaker
4 no comment just get a vesc
If your on a budget the Xcar is great. I use it on my penny board and it works great the only downside is the screeching brakes but I don’t use them much anyway. The little power switch is just for the esc but I use that to turn my board on and off. I do recommend getting an antispark plug tho from hobby kind for a few dollars. Oh and if you get the Xcar esc make sure to get the programming card too
The motor can take 10s but it will still work with 6s. Only. The esc will work. Not having the programming card is ok but having it will make ur board much better. You should get a Xt90s anti spark loop key. The loop key is to make sure everything is off when you put ur board in storage. If the off on switch fail on the esc the system might over drain ur batteries n distory it or even worst cause a fire. 6s 5000mah is good but I am concerned about the 20c rating. Maybe battery experts here can help you with c rating needed for your hookup.
I have had the FVT 120A and I have always loved using it, I heard the Xcar is around the same as the FVT so in my opinion it was a good esc.
I recently got the ebay esc and it’s really very good for it’s price (40€)
I should stay with the 280kV motor, one of the best and efficient 50mm motors I think.
