Hi everyone, I just received the cells for my evolve upgrade. I have tried different wiring configurations but in the end I will go with this
The problem with this configuration is that there is no where to put the bms unless i extend the enclosure or route the deck. I have no tools to do both.I am planning to stack the bms above the esc and use some rubber gaskets as risers for the enclosure so it will all fit.
Is this a bad idea? The esc gets really hot when riding so that might damage the bms.
The bms aids with discharging i believe so I am not sure if i want to put it above the battery pack as it might just get too hot and damage the cells.
Any advice?
