Found this BMS on hobbyking and im wondering if anyone knows if it would be good for my 6s build?. I dont think the discharge of 10a is high enough though so im just checking
Unfortunately your answer is right in the title of the BMS:
10A Discharge - no bueno for any e-board i know. While you don’t likely need a 100A discharge, you definitely need more than 10A. My dual 5065 setup showed a consistent peak of 40-45A iirc.
HTH - GL!
Yeah thats what I was expecting thanks though
You can use it for charging purpose but not for discharge purpose, its too low Amps. You need about 30A minimum with a better stability at around 80A discharge. If you plan to use it however anyway, better to connect the ESC / VESC from the battery directly.
