Looks good ben,thank man appreciate the help.
The part fits better on original abec rather than clones.
That file says m6 screws,does your 3d printed part use m5 Ben? I bought some 2" standard skate hardware which I think are m5 which fit the hobby king pulley.
I will have used m5. Pretty sure.
So is your pulley retainer ring m6 like that file or did you find a m5 file,just need to know before @moon starts the print!
I think I must have found an m5 file but for the life of me I canāt find it nowā¦
Arenāt you screwing into the pulley anyway?
Yeah Iām thinking it should still be ok as when torqued down should be tight but donāt want too much play,if I could get the exact size needed it would be best but i guess Iāll have to just try them.
Ok no worries I have been searching seems hard to find,think Iāll just get moon to go ahead with that file,the hole might be a little bigger but the head of the bolt will keep it in place.
Shall I go ahead mate?
This has taken a while
Yeah think it should be ok bro,all good Iām waiting on my focbox repair anyway,thanks man appreciate you helping me out.
I might have found the right STL with the 5mm hole. I can email it to you guys if you ping me you email.
@bigben @moon has already printed out the other file,he just wanted postage cost but I will obviously sort him out more than that,if you could get in contact with him and send the right file and he doesnāt mind reprinting then thanks.
Yeah sure I will print again
They should have gone over a few nights back? Did you check your trash?
Actually it doesnāt matter. We have realised that the first print I made was fine
