I have a Hobbysky 6384 that I got for cheap on Ebay. Looks like it’s in excellent condition, but I can’t test it because the leads don’t fit into the VESC. I’m getting some 5.5mm bullet connectors to solder onto it because it currently has 4mm. But my question is this: this has a 5pin sensor, but the VESC has a 6pin recepticle. Is it hopeless, or is there a way I can use the sensor?
@venom121212 Just looked through all of it. I wanted to solder it myself, so I was looking for a tutorial, but the ones in the search weren’t for the same thing. If it comes down to it, I can use
https://miamielectricboards.com/shop-1/oesc-motor-adaptor
or if I can find a detailed tutorial on which wires to solder to which, I can use this
so it looks like the one I can skip over is temp, is that correct? on the Vesc it’s next to 5v. Now all I’m unsure about is which colors on the Hobbysky correlate to which pin. In order, it’s black, orange, white, yellow, red. From what I’ve seen, red is 5v, and black is GND, right? So the order of orange, white, and yellow doesn’t matter. I’m just being extra careful so I don’t blow up my VESC. I know starting unnecessary threads is frowned upon, but since nothing was exactly the same, I just wanted to be careful.
If you asked this question instead of the original one, it wouldn’t be frowned upon at all. Just make sure you search the basics of your question and we’ll all be nicer
Ok, sorry. I just wasn’t sure how to put it. The Banggood wires have a different color order, but I guess that doesn’t matter. So I’ll get this, then solder the red wire from the motor to the 5v wire and leave a space for temp.
Your google-fu must be some weak shiz if you can’t use the power of keywords to find what you need
As my math teacher used to say, “exhaust yourself and the libraries surrounding you before coming to me for a drink, because I’ll make you drink the whole jug”
Also keep in mind this forum isn’t the only spot for esk8 advice, endlessphere has some great threads to familiarize yourself with parts and their intricacies
