Hi, I have Backfire dual hub esc and it was working really good for around a year. Last week I wanted to put everything on my Loaded Vanguard deck. I build new enclosures, drilled the holes, built a new battery, went out and the esc just didn’t turn on. I’ve thought that I didn’t connect the on/off switch or something so I went inside to check and everything was ok. The battery voltage is also ok. Does someone have the same problem and is there a guide to fix it? I checked the pcb board, top and bottom and nothing looks burnt or suspicious
What battery did you built? Is it a 10s battery too? AFAIK the Hobbywing ESC only takes 10s battery
10s cells yeah
Hobbywing has a 12S out there SOMEWHERE… Lock and Key…Shhhh… Beatttchhes…. Give us the darn key.
gut an exway board for it
mine is doing the same as well. i get two red flashes from my power button then off. its got a full charged battery 10s as well.
