Mine arrived yesterday, they’ll be going on the tb dd.
thats the second shot of those wheels I’ve seen then they look unfinished
They basically let a bit of the rubber smear on the core. It’s not a big issue imo. After 10 miles they will be covered in bin juice and salt anyway
Should I send you the invoice for the research? Because I never got your purchase order… Here is the first one I found
Is that where you’ve been all night? Missed ya lol
That was literally me talking about the difference discerning between waterproof and water resistance. Notice the parentheses?
Now here are screen caps of me using “waterproof” in place of “water resistance”
Edit: I should note this is every screen cap of that word dating back to 2017. No crops no clips.
Note how that dates all the way back to 2017 when I first became active in the community.
In that screenshot, I said quote:
I’m already making the precautions to make the electronics and battery enclosure entirely weather resistant
I suppose because I wanted to point out that nothing is truly “waterproof” and that everything is actually “water resistant”, that makes me a harsh opponent of “waterproof” esk8s.
If you look at what I said above before you changed it
Then you’ll see I am right. You had little genuine interest in making your production board waterproof. You wanted to do the standard pretend-we-care add some water-resistance stuff and drop it.
Things can definitely be waterproof, beyond water-resistant, but you had no interest in pursuing that. That’s what you’re showing now and what I was referring to.
Don’t change my words around LoLz.
I’ve sent you an invoice for the research.
What? I make the board water resistant to the best of the CF design’s capability, halted production and chose different “waterproof” hub motors (on my dime), and employed the use of PG7 waterglands to make this board as water resistant as possible. It was made for a niche market that wanted a commute tool that wouldn’t instantly die from wet salted roads, in which it succeeded in accomplishing that task. Now you have the audacity to say that I didn’t really care? Okay.
My wheels arrived today
https://imgur.com/gallery/3oLMynn
Funny thing is that they also sent me shitty bearings even though I didn’t even pay for it.
Note the harfang stage 1 tread pattern.
Has anyone actually tested these in the rain? If these provide significantly more grip than urethane when the roads are wet, I’ll pick up a set to throw on my torquedrive’s when it’s rainy.
10% off with code NYCEBOARDING for new years
Sooo, we really need a review on these. Have you tested them yet?
Still waiting on some of my parts. Hopefully my build should be complete within the next 2 weeks.
The rains not going away anytime soon where I live. Lots of time to test.
they also sent me two “free bearings” that i didn’t order either
