So I am trying to calculate my setup’s average amperage draw while riding. I am riding a 10s2p with 192kv motor. I know that you can provide realtime bench test data on the VESC but is there anyway to collect ride data when riding? A bench test would not actually reflect the amount of amps being used to power the board with weight…
Go for a ride. Time the ride. Run the battery from full charge to the cut off voltage.
If your battery is a 5000mAh battery and your ride lasted an hour you had an average amp draw of 5A.
I actually just did a riding bench test on a treadmill…it was pretty sweet!! Awesome seeing the realtime data pumping onto my laptop screen…It felt like some sort of high tech testing in a movie
