Hello, i’m making my own electric longboard or skate like everyone in this forum XD.
My big question is. How the F*ck i charge my battery (i’m not angry, just make more dramatic, peace)…
I know how to construct the battery 12S1P or 10S1P and i need a BMS. I will use lipo or li ion, and my be use this bms https://www.ebay.com/itm/362070141286?rmvSB=true but whats next. how i plug? and what to plug?
I really need this?
I can’t make a USB connection for charge any place, or just use a normal charge like portable computer, have to be a futuristic charger. and for last questionm how is the charger boosted board.
Thank guys for your time, and i wish this help futures builders
I would suggest that you do a lot of reading in the Esk8 build category before proceeding.
You will have a much better idea of what you want or need and you will be much better equipped to do the build.
i already read and search a lot… at least 2 weeks. and i have chosen the wheels, motor, gears, vesc… and the battery and charger it was the last item. but thanks for the advice
Thinking that you can charge an esk8 from an USB plug “any place” shows a real lack of understanding what an esk8 is and how it works and is built. Read, read and read a lot more before you go further into this esk8 DIY hobby because it may be more difficult than what you think (But I may be wrong), more expensive (DIY is usually more expensive than “ready to ride”) too.
" construct the battery 12S1P or 10S1P and i need a BMS. I will use lipo or li ion" --> There is no li-ion battery with only 1P on an esk8 ! But 1P is prevalent in lipo.
2 weeks reading is a joke if you want build, understand and maintain you esk8. My guess is you need more, really. Hope this help ! I’m not mocking you, I just want to be sure you know what you put your hands into.
the problem i found is the compatibility of trucks and mount, and the trucks of hobby king is out of stock for ever…so i have to change. and i choose this trucks is my be i can mount two motors, but i have to see if i have space, when i receive the product
i lost a lot time looking for dual, but i have change for 1, and my be this will work, but i just will order one motor and assembly all, and after if i have space order the second motor
