I have just completed my first build using Flipsky VESC6.6 and a 5065/270KV motor. The first trial at max speed lasted only for a minute until it went in to power limit and I think it is the motor temperature sensor which is a bit too sensitive.
It shows 80 degrees when the can is lukewarm.
I have increased the beta factor and now it works well but I would like to know if it is common that this factor must be adjusted?
