I built a 10S5P Liion battery. Bought a 10S 50A BMS that I want to use for CHARGING ONLY. I plan to have a switch that swaps the connection between BMS and VESC. I want to know how to wire the BMS since I am unsure. Here is an image:
There is a B- and P-. Which wires do I connect to these?
EDIT: I already soldered the balance cables on the battery and understand how to connect them.
