i looked through a lot of pictures here, but i can hardly see, how you guys fasten your XT90 or 60 keys in your case. I glued mine in, but now its to short and the connector comes lose everytime i ride.
yea, but do you have a picture? what i mean is, if i glue it, then a small part of the plug stays in my housing and can’t be used for the other part of the plug, which then is too short. i hope you know what i mean.
Tuomalar thanks so much! That makes sense. I have the female part in my enclosure and the male part goes over it. But it can not go all the way in. But your solution is so simple, i wonder why i didnt think about it. I feel pretty dumb now, but also am happy because i’ve got a solution now. Thanks guys!
There was an argument not long ago for not mounting that way as it leaves the pins exposed and able to short. I’m not really sure that is much of an issue but I mounted mine male end in the case anyway. I understand what you mean about the thickness of the enclosure meaning that the female part doesn’t fit fully over the male. I cut a wooden holder and worked out positioning then filed the hole out to the right size. sanded the area around the XT90 a little thinner and then hotglued it up against it. It wont ever work loose and probably only short by about 1.5mm which hasnt caused me any problems.
I mounted mine with the male pins in the case too because I had an issue where the anti-spark-plug (female part) was still giving off sparkes, probably due to wear of the resistor / internal contacts. This way, I can switch the female side much easier. To protect them, I printed a cover (found in the thread smorto linked above).
Thanks a lot! Just one of them (XT90 or XT90-Pamel Mount) is fine for me. I can deduce everything I need from just one of both. Finally I want to make a 3D-printable model of a XT-90-3-Plug-T-Adapter where the power connector from the battery, the loop key and the power connector to the VESC are linked together and can be fixed to the board.
At the battery I always use female, the V*** (ESC formerly known as VESC) has male - so I have to use the corresponding counterparts. Currently I think I will use a male for the loop key, so the T-Adapter will have female.
