jrpwit
December 25, 2017, 12:25am
#1
Hey guys!
I have been doing some welding with the aulakiria welder aka the “boss level” spot welder. It works great!
I am just wondering how other’s welds look. Here is how mine looks so far…
How many welds if recommended what does a good weld look like? Thank you!
A good spot weld is when you can’t pull the strip off with pliers.
jrpwit
December 25, 2017, 12:28am
#3
With these the nickel will tear if I try and pull it off.
welds are good, but you might want to do multiple layers if it’s an eskate battery
Using Malectrics Arduino V3.1 spot welder
jrpwit
December 25, 2017, 1:15am
#8
Thanks everyone!
I lower the welders milliseconds a bit @Namasaki
JLabs
December 25, 2017, 1:23am
#9
Yup exactly what @Namasaki said.
Also do not use the nickel strip that is provided with the welder. It’s nickel plated steel and is not suitable for our use. I just used them to play around with the welder when I first got it.
Performance varies with source voltage too so keep an eye on it as you go for changes and adjust accordingly
jrpwit
December 25, 2017, 1:42am
#11
Yeah I heard that. This is 0.2 pure nickel from batterysupport.
I also sanded a piece and threw it in some salt water. All good.
jrpwit
December 25, 2017, 1:47am
#12
I also noticed that the temperature of the fets which is displayed makes a big difference too.
When it’s at like 25°C it’s heaps stronger than at 35-40°C
rojitor
December 25, 2017, 1:22pm
#13
For 0.2 7ms is the usual flux time.
jrpwit
December 25, 2017, 4:09pm
#14
After messing around a bit, that seems about right.
Thanks and Merry Christmas!!!
