hey im building an emountainboard and was wondering how far my build could reach with these?..
i will be using vesc6 with 190kv torque motors i weight 140 pounds mostly on flat ground not to many stops just wondering for a rough preditction if i had 2x making 12s
This Turnigy Graphene pack seems like a better deal than building your own 30Q pack. What am I missing here? What is the advantage of a 12s4p 30Q pack over this, specially if you don’t have a spot welder? @Namasaki Maybe you could answer this, since you know a lot about Lipo packs.
With 18650s you can get higher watt hours per unit volume (higher energy density) but typically lower discharge rate per cell. Lipo also typically consider safe cut off around 3.5-3.7V per cell since voltage sag can be significant but this varies cell to cell regardless of packaging or particular cathode anode or electrolytes used in the cell, in general though I’ve seen people with 18650s using lower cut offs and seen ratings on cells with lower min voltage.
Lipos are cheaper in general (doesn’t always apply).
Liions are more energy dense (more energy in a smaller space)
Lipos are more power dense (but liions are more powerful than more than 90% of the riders here need)
Liions will last at least twice as long.
