Hello everyone,
I’m planning to build some electric longboards with friends, but I don’t know how many batteries to buy for each one
We will use a SK3 - 6374-192kv as a motor with vesc homemade, a 60V 12S 60A BMS and LG HG2 (3000mA - 20A)
We are looking to build a 10s battery but how many parallel batteries should I place to be getting a powerful skateboard without getting something extremely expensive ?
Thanks you for your help and all your interesting subjects on this forum
The 10S will give you the power. The more cells you put in parrallel the more you will extend your range.
There are some Esk8 calculators that can give you an approximate range and speed depending on your configuration.
If it’s a long board 4P should already get you quite far.
@jga But if my battery can only deliver 60A with a 10S3P, to be cheaper, the motor witch is a 80A will be powered without destroying the battery by taking more amps than what could be delivered by the battery pack
The VESC once configured should ensure the regulation between the battery and the motor.
I am not a battery specialist but from what I have read on the forum you should be fine with 60A. I doubt you will pull that amount on a constant basis, probably closer to 40.
