99% nickel strip bought from nkon so its legit, few weeks ago i finished a pack for my board and now suddenly while skiing I realised that I forgot to put another layer on the terminals and now its already connected with a bms so its a bit trickier
cells are 30Q in a 4P configuration
nickel strip is 6mm wide and .15 thick
Im really hoping that I will not have to use my shitty improvised spot welder again
Your battery can put out 80A max. There is no way that little nickel can handle that much current. 10mm 0.15 nickel becomes hot at 15A, so I’ll guess your 6mm 0.15 nickel can handle about 10A max continious… Which means; you really need more nickel to be safe
If I were you I would have got some 10 or 12mm wide nickel strip. Then I think 2 or 3 layers should be good enought.
But If I remember right, I think that it is the serial connections Who is critical, Since more current will pass there, compared to the parallelle connections. I am not sure tought, so double check with a more experienced one like @barajabali or @darkkevind
don’t just layer nickel on top of nickel. do some tests.
i’ve noticed a nickel to steel (cell) weld is far stronger than a nickel to nickel weld. i’ve had to redo a whole set of welds because a 2nd layer of nickel, after time, just started falling off on its own. i was using a sunkko 709a.
I second this… For some reason the nickel doesn’t weld to itself very well so I use heavier nickel in the first place. My series welds (mostly because I need a flexible pack for Evolve boards) are all done with 10awg silicone wire which can easily handle the current.
I advise using the widest nickel strip you can for your series welds, 15/18mm 0.2mm strips should be sufficient for esk8.
I’m convinced literally everyone is mega overdoing it. I hardly have anything real to back this up I just have never heard of anyone ever burning up strips due to not being able to handle current.
One strip of .15 thick for me. And it’s a 13S4P pack that’ll pull prob 45-50a at bursts lol
