My old RC chargers didn’t go above 8S.
Here is what I used to do to charge higher packs:
You need to have 2 independent batteries:
Battery 1: Main negative needs 2 wires, one connected to ESC connector ground and second to charging connector 1 ground. On the positive side, you need a single wire to charging connector 1 positive.
Battery 2: Main negative needs 1 wire connected to charging connector 2 ground. On the positive side, you need 2 wires, one to ESC connector positive and one to charging connector 2 positive.
To charge, you connect charging connector one to one charger and charging connector 2 to another charger (or 1 per channel on a dual charger)
To turn on, you need to connect charging connector one positive to charging connector 2 negative. Yes, it doubles as a loopkey.
So battery 1 is the top row of cells and battery 2 is the bottom. I bought one black and one yellow set of XT60s so I would not confuse them when plugging in the loop key, but it would not matter if you did. The board would simply not turn on.
You also do not need a connector between the ESC and the battery but I had one since it was just a temporary solution
Nice artwork If you look at the photos I posted above, that block is the loop key, and it blocks the balance ports. It serves as a mechanical lockout so you can’t connect both.
So if I leave the loop key in, it’s one pack and I charge from one port, and if I remove it it’s two packs and I could just a balance charger on both charge ports. Right?
At least, that’s what it looks like to me… Could I use one 12s BMS or would I need two 6s BMS?
Yes, you could charge from the ESC port but you would not be able to balance unless you made a harness that joined the two balance plugs.
Yes. But if you have a harness joining the balance plugs together and try to charge, you would blow up something.
As long as you disconnect the BMS harness from the battery to charge the 2 packs individually, you can use a 12S. Having 2 6S BMS would overly complicate things
If you do 12s BMS don’t bother with all the rest of this – it takes a surprising amount of room to make all these splices and connections. Just check cell voltages somewhat frequently with a volt meter until you develop some trust. IMO.
