I am having trouble as the remote to my electric longboard has gone missing and the only other controller I have is the Yuneec E-GO Cruiser controller. Is there a way to connect this to my DIY board with a source VESC??
Does the yuneec remote have a separate receiver, or is it built into the yuneec board? If there’s a separate receiver, then you should be able to connect its output to the vesc. If it’s integrated, you’re SOL and you have to get another remote.
As long as you have a remote and a receiver that talk to each other, and the receiver has a signal that the vesc can interpret, the possibilities are endless. RC car remotes, wii nunchucks, the list goes on.
2.4GHz is preferred because it’s a robust communication protocol, but others have been used.
