Hi everyone, I’m finishing my first build but I need some help with the geardrive. I’m not a mechanical engineer so this is getting quite challenging.
I’m doing a 12s4p 190kv motor build and retrofitting an old mountainboard.
My idea was to laser cut the gears and motor mounts from a sheet of 8mm aluminium. And then 3d print an enclosure too keep everything away from road debris and the lubricant inside.
My problem is how to design the gears. Is there any tool I can use? I’ve design the motor mounts in fusion 360, but I don’t know where to start with gears.
I searched online and found https://geargenerator.com/#200,200,100,6,1,0,902.1000000000228,2,1,11,2.75,4,27,-90,0,0,48,12,4,27,-60,0,0,2,292 but if I try to import into fusion the measurement aren’t correct, the gears end up bigger than stated in the website.
(I got the 11:48 from the esk8 calculator, I would like to increase 48 to a bigger number but the size of the gear would be too big?? maximum is about 120mm~130mm with current wheels)
