No sensor wires, sorry, I forgot to say that. A weird thing once or twice the VESC tool has given me Fault : FAULT_CODE_DRV Current : -150.2 Current filtered : -17.0 Voltage : 38.26 Duty : 0.712 RPM : 347.0 Tacho : 5 Cycles running : 19 TIM duty : 4076 TIM val samp : 2038 TIM current samp : 4899 TIM top : 5723 Comm step : 3 Temperature : 30.97 but then it has just disappeared giving me just ABS fault Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 151.4 Current filtered : 133.5 Voltage : 38.20 Duty : 0.001 RPM : 40173.6 Tacho : 3 Cycles running : 0 TIM duty : 2 TIM val samp : 1050 TIM current samp : 3150 TIM top : 4200 Comm step : 6 Temperature : 30.60
Drv error always bad sign Where you located? Maybe you have a local repair service around the corner?
yeah I know, but why has it disappeared? The support team told me that if I can upgrade the firmware DRV is fine…I’m located in Italy, I should take 40 min driive to get in a computer repair shop…
Shoot @Martinsp a pm. He repairs all kind of vesc. Maybe you can work something out together.
