Hi guys,
Absolute noob here with a different sort of problem. I have a project (started by someone else) that uses a Flipsky Mini FSESC4.20. It runs a 120KV motor and has I think an oscillator circuit that the VESC receiver cable plugs into. Pins 2 and 4 of the Hall sensor input (Flipsky ID’s them as H3 and H1) when connected/shorted via a switch would turn the motor on. I updated the firmware and calibrated the motor (I have a new motor in there now). The entire process worked out fine, the VESC went through it’s steps of beeping and rotating etc until the app said it was all done. However when I now try to switch it on (via that pin H3 and H1 connection) the motor does not rotate. I must have removed some command inadvertently when I calibrated the VESC to the new motor because it worked fine before.
Can anyone offer help and advice here? How do I program/set the VESC to turn the motor on (at full throttle) by means of a switch instead of a transmitter/receiver? Any help appreciated, many thanks in advance in guiding a noob here.
Cheers, Kris
