How to get vesc to 100% duty cycle?
im stuck at 95% something on the bldc tool its not adjusting on the remote
@Hummie how are you measuring this? Is it a problem with the max/min PPM settings for your remote? If you’re not able to hit 100%, try adjusting the trim of the throttle on your remote first, and then tweaking the max and min PPM inputs.
You can’t, vedder explain this somewhere, something to do with the VESC 4.x only having current measurement on 2 phases (2 shunts) so it need at least some time with the transistors off so it can measure que current flow
Ooo. Yea I tried the transmitter trims
