Basically I wipe out every fucking day because the ground I ride on is always covered in dirt and salt (college campus under construction all the time). Usually the asphalt treats me okay but the brick is impossible to ride on. Is there a way to not slip-and-slide every time there’s a patch of loose material?
I’m kinda worried that when I get it motorized with a good battery that it will be impossible to ride
Disclaimer: I’m not riding an esk8, its a long and narrow board with loose trucks but it has ABEC 11 90mm and most of the time I fall when pushing but it will still spin out when cruising in a straight line at 10mph on flat ground half the time
Back in fall I was using the same board on harder wheels and it was totally fine but the ground was always clean back then so its not the board or my style
You turn hard when you see clean, smooth pavement in front of you, and when you see or feel debris, you avoid leaning much and if you have to lean, you slow down.
Good point, it’ll probably work for now since there’s nobody around yet and I guess heavy foot traffic should clear the walkways eventually when they do come back
