Hey there, right now i am quite stuck… I have some broken vedder switches which i want to repair.
Now a little bit of story: One time a broken switch just revived by vibration… the board with everything equipped was dropped from 20cm height. after the fall the switch just started working again… duno why…
Another switch did not power on at all. After some unplugging, changing the position of the softswitch and reconnecting it the esc got power. Then i have turned it off and it powered down. Since then the switch was working again.
Then i tried to revive another switch with the same method but it did not work at all.
Does anybody have an idea what could be the problem? Would be great if you @chaka could chime in here because i think you have the best knowledge about these switches but everyone is welcome to help.
