Hey guys, I want to build a 6S3P battery pack and have found this image:
http://esk8content.nyc3.digitaloceanspaces.com/uploads/db2454/original/2X/1/190c03d8cc2d64b85cf002205c9d553b463a0bf4.jpg
But instead of a BMS I want to use a Imax Charger. I have 6S JST connectors, but they have 7 pins instead of 6 as in the image. How would I need to wire this up?
6s batteries have 7 pin JST-XH balance plug. First pin (well pin 0) is what you see labeled as B- on the image.
Thanks for your response! So I can just shift every pin starting with B- and I am good?
Like this:
Exactly. That is the standard pinout for a 6s balance plug.
First wire goes to main negative. The rest to positive. Last wire is usually red and goes to main positive.
I used a balance wire in this video:
https://youtu.be/iYOh_15mri8
