Hi Everyone.
I am thinking about my new board, and i would like to know how to wire up 2 ESC. I know how to wire them through the direct connection from other threads.
But what capacitors should i use? I guess in theory could just 2x (double size of the ones on a single VESC) But i dont know how many Uf they are
Can someone help me with the uF for a standard VESC and if doubling the uF would work the same way with then only 2 Caps?
I found this great board design for 2 VESC’s
I found that each Maytech VESC has 3x 680uF Caps.
Can i then use 2x 2200uF? like these?
Yes you can do 2x 2200uF in parallel, but aliexpress may not be a good source of components. The caps are under fair bit of stress so maybe go for a more reliable source. But in theory the answer is yes 2200 in parallel will do just fine unless you are doing some crazy long battery wires.
What would be a better supplier in europe ?
Where exactly?
Uk area farnell
germany area probably TME
EDIT: Farnell is your best bet most probably though, they have a lot of components and shipping is just 4,9€ or something like that so pretty decent
Thoose are good bets i will look at those i live in denmark so just between UK and DE
